I recently bought a Mastercraft used nail gun from marketplace, which is normally used for baseboards. For reference images are attached.
I was using it with my Air compressor and it was working all good, after nailing about 15 nails when i fire a nail it only gives a sound (like normally it does) but does not fire/hit the nail so nothing happens.
I was using it at 70 to 90psi presure which was recommended for this model, I checked nails were not finished but still I loaded bit more, I can't see any nail stuck in it, any idea what could be the reason?
Check again where the nail comes out. There may be one or two nails jammed inside. They may not be visible from the outside. You can disassemble the nail head to check inside.
Does anyone know what this support is called? It's used to support a wooden board, and you can place some miscellaneous items on the board. At one end of this support, there are three clasps, and one of them has broken. I'm thinking of buying a replacement, but I don't know what it's called. It seems to be made of iron.
anyone knows where can I buy it?
[img]https://cimg8.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/img_3375_cc54cc0a01bd9316f6a9f0b416ed818c08b11af0.jpeg[/img]
[img]https://cimg9.ibsrv.net/gimg/www.doityourselft.com-vbulletin/1603x1150/img_3374_24c2d7ea6bedd3cc513317e617dfcef51ee81ca5.jpeg[/img]
Read More
