Curtain Rod Problems
Old 04-05-02, 10:15 PM
bbop
Unhappy Curtain Rod Problems
While hanging curtain rod brackets the nail will not hold firmly enough into place thus causing the curtain & rod to come completely out of wall.
Any suggestions?
Old 04-08-02, 08:10 PM
cheese's Avatar
Received 119 Upvotes on 109 Posts
Sounds like you are nailing into drywall...you will need at least screw anchors to hold it up, or you may need molly bolts...depending on the weight of the curtains & rod.
The screw anchors should be available at any hardware store and will probably suit your needs. If the curtains are very heavy, I would look into ways of anchoring them to wood.
