Sliding glass door roller repair
Old 05-24-02, 07:53 AM
sorrelmb
Any tips on replacing rollers on a sliding glass door? Rollers are worn out. I've seen replacement kits at local ACE hardware store.
Old 07-06-02, 11:09 PM
some help
Hello
Yes most harware stores have a replacment kit...you will need to remove the door and take out one of the rollers to take to the hardware store with you to match up with the new one....To remove the door open it part way and lift it up off of the track and lay it on the floor....you may need to use a small pry bar to help lift the rollers off of the track.....Be carfull take your time....if you are not sure you can do this safly get help from some one who know how to do it....better safe than sorry around glass....Good Luck....
