Bolts
Old 06-03-02, 10:56 AM
putteraround
Question Bolts
What type of bolts would I use to bolt something directly to a wooden structure. I do not want to screw in the bolt. The bolts must be a "machine" type bolt. Can a bushing (right term?) be sunk into the wood so the bolt can be removed when necessary?
Old 06-03-02, 04:27 PM
George's Avatar
A sradard hex head bolt can be removed without the necessity of a bushing. The size and grade will be determined by the load factor on the shaft of the bolt.
For extra security, look for a grade 8 bolt. Much stronger than standard (grade 2) and not that much more expensive in small quantities.
