Are screws ok for wall framing?
Received 0 Votes
Hi there,
I've been reading the BOCA and CABO code books about requirements for framing walls. All the charts and tables provide the required nail size for various applications (stud to sole plate, sole plate to floor, etc.).
Is it possible to use screws instead of nails? I've seen a 2 1/2" and 3" drywall screws used to attach studs to top and sole plates, but I don't know if this meets code. Does anyone know for sure? If screws are permitted, is there a screw equivalent for each nail size (e.g. a 6D nail could be replaced by a 2 1/2" wood screw)?
Also, can I reduce the number of fasteners required by using adhesive in addition to fasteners?
Thanks!
Thanks!
Equivalent strength screws are acceptable, and are used in historic home repair to reduce vibrations that could damage old plaster walls. However drywall screws have minimal shear strength and do not meet code for any use other than supporting drywall.
Thank you Jeff!
I work in a building supply and I can't count the number of times people have ocme in complaining about the 'lousy' screws' that broke - when they were trying to use a drywall screw to hold two pieces of framing together!
Some years ago I built a 22X8 porch on the side of my house and used screws throughout - galvanized deck screws (square drive). I even tied the rafters down with a 6" (#16) screw from the top through the 'birdsmouth' into the header. It's rock solid.
