Treamill Proform 770 jerks when I run
Old 12-29-09, 12:45 PM
B
Question Treamill Proform 770 jerks when I run
I have a Proform 770 EKG Treadmill that jerks when I run. It used to sqeak when I ran (only when feet land) but now it jerks for a half second then continues on again. This only happens when running hard, not when walking. Any idea what to look at?
~Thanks in advance
Old 12-29-09, 01:38 PM
P
Received 1,765 Upvotes on 1,578 Posts
Try looking at the bottom of the conveyor belt on which you run. Most belts have a slippery type backing and the frame of the treadmill has a smooth steel, plastic or graphite sheet to keep the friction to a minimum when your weight presses down. If either is worn or missing your weight crashing down when running creates a huge amount of friction for a second causing the treadmill to slow down or briefly stop. I can also say from experience that a spilled drink can cause a similar problem if it seeps under the belt.
If that is not it. Unplug the treadmill (safety first). Then remove the cover over the motor & drive area. There should be a drive belt running between a pulley on the motor and another pulley on the running tread/conveyor. If this belt is worn or if the tension is too loose it may slip under heavy load (when you are running).
Old 12-30-09, 06:46 AM
B
Thumbs up Fixed
That did it. The motor just needed to be tightened a smidgen.
I took everything apart and the belts appearded fine. I ran on it again and made the jerking happen. Then I could see that the motor kept turning but the belt was slippin on the motor output shaft. It did not appear loose but I tightened it just a minor bit and that made all the difference.
~Thanks!!!
