Treadmill won't start! Help!
Received 0 Votes
Hi,
I have a two-year old motorized treadmill.
The other day,I switched on the power at the bottom (where the plug is inserted) and the LCD panel came on for two seconds and then disappeared completely.
Now the red light switch at the bottom is on suggesting power is entering the machine but the rest of the machine and LCD panel is dead.
What could be wrong? Any easy solutions? Warranty was for a year I guess.
Regards
Regards
The only easy solution is probably a blown fuse. Some have the accessible from the outside usually near where the power cord enters while others have it on the inside of the unit. Other than that most/all treadmills are electronically controlled. You might be able to spot a blown component or if you look closely find a cold, broken or cracked solder joint.
If it isn't a blown fuse then only option to replace it ?
Got an owners manual? That might show where it's located.
Start with the easy items first!
