Electric Stair Lifts
Old 01-04-20, 01:10 AM
kolias's Avatar
Received 7 Upvotes on 7 Posts
I find it harder to climb the stairs in my 2 story house and I was thinking about these electric stair lifts I see advertising on TV.
Does anyone has experience with these stair lifts?
Old 01-04-20, 04:25 AM
XSleeper's Avatar
Received 1,703 Upvotes on 1,527 Posts
Just that you usually contact a home health care business to purchase and install them. They require service after the sale, since most have a battery backup.
Old 01-04-20, 05:04 AM
Norm201's Avatar
Received 663 Upvotes on 586 Posts
My wife and I will seriously consider one when we get to the point that climbing is getting to be a problem. But what are the typical "service" required? Most companies offer a one year service with their warranty. For all intents and purposes is not much different that a garage door opener. And they don't need much maintenance.
Old 01-04-20, 05:05 AM
pugsl's Avatar
Received 76 Upvotes on 69 Posts
I had them priced for my home. Brand that is advertised on TV and they were 3500$ per each set of steps. Did not matter how many steps just a straight run. Each landing cost more. I think they said full service but I don't remember how long.
Old 01-04-20, 05:18 AM
GregH's Avatar
Super Moderator
Received 66 Upvotes on 61 Posts
Curious to know what a set of steps is.
Is that a continuous run?
We are not quite there yet but have a spark of an idea that I may look into becoming a dealer/installer for these as a retirement job.
As said they are fairly simple but have critical components that keep riders safe.
Old 01-04-20, 07:46 AM
kolias's Avatar
Thank you guys, just got a feel about them but the cost? didn’t think they will be so expensive. That’s taking advantage like the hearing aids.
Old 01-04-20, 11:56 AM
Received 3,415 Upvotes on 3,063 Posts
Yes..... they are expensive. Many insurance companies will cover them or partially with a doctors script as they are potentially life (and fall) saving.
They are easy to install but not a typical DIY job. I have installed several and moved others. I have two sets in my parents house that will be coming out. They require very little service. The models I've worked on and highly recommend are the Bruno SRE-3000 series. They use two lead acid batteries beneath the chair. They require a receptacle near the track as charge power is sent to the chair via slide contacts on the rail. The chair basically runs on 24vDC battery power. They have an up/down control on the chair as well as wireless remotes for the top and bottom.
Old 01-04-20, 12:17 PM
kolias's Avatar
PJmax that's quite more informative, thanks
