Reebok 3500c motor stopped working after belt adjustment
Old 01-13-20, 12:50 PM
I have a Reebok 3500c treadmill. I adjusted the belt a bunch of times trying to get the right fit, then one day the motor tried to start up and instantly shut off flipping a breaker. SInce then I can plug it in, press start and it tries to start up but won't and shuts itself off then turns back on but the control panel only, not the belt running. ANy idea what happened? How can I tell if I need a new motor controller? The fuse is not blown and everything powers up, it just won't run...
Old 01-13-20, 03:21 PM
Received 296 Votes on 270 Posts
Did you over tighten the belt? Try releasing ALL the tension on the belt so the motor is just turning itself and see if it runs and doesn't trip the breaker.
Old 01-13-20, 03:44 PM
I think I may have over tightened the belt initially, i have released the tension some in previous attempts to get it to turn on, I will try all of the way as you suggested. Thank you for the suggestion, I've been trying to fix for awhile now
