reached a plateau (bench press)
I have been slowly working my way up from 160+. Started back in June when Gyms opened back up. I have very little knowledge as to what I am doing but still progress with strength. I run 3x3s at my max then throw on another 10lbs with just one rep. I am stuck at 270 3x3. I can put on 290 and push it once but it hurts and there is no way I could push it twice let alone 3 times and 3 sets. I have been stuck here for a month now and i go to the gym every other day. I warm up with 20 min of cardio and before hitting 200s I warm up with lower weights first. why am I stuck here? Am I doing something wrong? Am i not working out enough? am I not warming up enough? I am 5'7 170 lbs. end goal would be benching 300. I would be happy with that. And advice would be much appreciated Thanks.
I always have better luck with a mixed routine and only do max/heavy once or twice a week. The rest of the week is doing lighter weight for higher reps and mixing up the routine working on other body parts.
I used to be a bodybuilder, not professional tho. I got to certain weights at some point and I too, stopped at a certain weight. I think maybe it's just the limit a body can do without going the steroid route.
Are you working your whole body and drinking your protein drinks? I think making your triceps stronger also helps.
If you only started back in June, you're doing pretty good I"d say. I think you just need to be patient. Professionals work out a lot longer than that to get where they're at.
I started using a new workout where I went right to the heavy weights and skipped the lighter ones. Took less time to do a workout and was more effective.
After reading PD's reply, was reminded that I too, worked different body parts on different days and varied the exercise. Doing the same workout every time will cause the muscle to become stagnant. Do other exercises besides the bench press sometimes, altho still do the bench press.
Poor choice of words as I meant the DIY website. 95% of the forum mailboxes are for personal property problems with home, vehicle or land. The remaining 5% cover most of life's other problems. A leaking natural gas line from the meter going into the home isn't a personal issue while amount to exercise is.
I know what you meant and you would be wrong to suggest this type of question doesn't belong here. We wouldn't have a health and exercise forum if it didn't. I doubt they would have gotten better answers elsewhere. No one suggested they do anything dangerous. Also, no one is forced to listen to any advice given here, no matter what the subject.
