Electric Baseboard heating
I was thinking of getting gas baseboard heating installed in my basement until I became aware of electric baseboard heating. My electrical contractor said that if I purchased it, he would hardwire it to my panel. Does anyone here have electric baseboard installed in their house wired to their electric panel?
best electric baseboard heating solution?
I'm thinking about using electric baseboard heating as a secondary heat source for my finished basement. The finished basement area is 735 sqt feet of open space. I have gas furnace forced air as my primary heat source, but I don't think it will bring the room to the level comfort I want. I will have the electric baseboard heating system controlled by a seperate thermostat. And the electric baseboard heaters will be installed on the outside wall under windows.
My problem is selecting the right electric baseboard heater for my application and size. I have the following questions for starters...
1. Will a sealed silicon oil electric baseboard heater perform better the than standard ones (i.e. control room temperature swings and/or lower cost)?
2. Do you recommend units equipped with blowers or fans?
3. Are there more ascetically pleasing baseboard heating options available?
4. Lastly, is there a particular brand you would recommend?
Thanks,
Jasper
Thanks,
Jasper
