GE ECM Variable Speed Motor -- retrofit ??
I'm contemplating replacing my multi-speed blower motor (use hi/lo) with a new GE ECM 2.3 variable speed electronic commutated motor.
Q. Can I order a GE ECM blower motor as a retrofit? or
Q. Will I have to secure a major make's part number of an ECM for an existing system similar to mine?
My System
I run the system fan continuously and figured I could save a few kwh during FAN only and low demand times by converting the multi-speed blower motor to a GE ECM variable speed motor.
Thanks in advance!
My System
- Installed = 1993
- Region = Tulsa
- Outdoor coil = Carrier 38YR heat pump, 3 ton
- Indoor coil = York horizontal slab coil, 4-ton, w/TXV
- Furnace = Hydronic, 52K btu, w/blower (water heat w/forced air)
- Boiler = Two A.O. Smith FSG-40 water heaters (also domestic hot water)
- Variable Air Volume = Carrier Comfort Zone (3 zones)
Thanks in advance!
after a lot of thought and questioning other pros, here is what i come up with:
changing the motor will require changing the motor controller.
a new circuit board that runs a unit similiar to yours will be needed.
it can be done, gonna get pretty technical and pricey. a new VS ahu may be cheaper in the long run . new parts, warranty, etc.
11 yrs old, i would replace it.
probably looking at 650 for parts to upgrade, ball park figure
replacement with vs here in atlanta, just over twice that, has new coil, etc
