How hot do electric baseboard heaters get?
Old 08-03-04, 12:45 PM
elf_brewery
Can someone give me the maximum temperature an electric baseboard heater will achieve?
Many thanks!
Old 08-03-04, 01:08 PM
mattison's Avatar
What size heater is it? If you remove the covers you may find a rating on there probably in watts or kw.
Old 08-06-04, 04:12 PM
elf_brewery
volts and watts
The small heater (26") has a tag reading: 240/208 Volts, 500/375 Watts; one of the large ones (7') reads: 240/208 Volts, 1750/1312 Watts. Hope that helps.
Old 08-11-04, 10:43 AM
Ed Imeduc's Avatar
Wink
If you mean will they burn. A cloth right on top of them will start a fire. Or a kilowatt is 3415 BTUs of heat.
ED
Old 08-11-04, 11:40 AM
mattison's Avatar
They want to paint them. I can't get any clear answers on surface temps but I know we painted ours at work with and oil based enamel.
