Duct work figuring
Old 10-20-04, 03:43 PM
dssatlantic
Duct work figuring
How do you calculate ductwork layout and size for a heat pump
Old 10-20-04, 05:08 PM
Ed Imeduc's Avatar
Received 1 Vote on 1 Post
Same as a AC and furnace. 60 sq" per ton for a tight job and on up to 80 sq" per ton for a good job. Think about 400 cfm per ton also. So for a 3 ton tight 1200cfm need about a 8X24 duct. You have to know what you have to start with
Might go to htto://www.llbuildingproducts.com
ED
Old 10-25-04, 08:58 AM
dssatlantic
3 Ton
I am starting with a 3 ton heat pump. i was told you need a certain size ductwork to get best effiency from heat pump. I was also told if you had wrong size ductwork it was hard on compressor?
