house heater throws the breaker
Received 7 Upvotes
Need More Detailed and Specific Information
Hello: centaur. Welcome to the Do It Yourself Web Site.
Only suggestion at this time is: Need far more information.
Type of heating system would be a start.
Electric heating???
Heat pump???
Brand name, year and model, if known and possible.
Locate the manufacturers plate or sticker to find the info.
I moved your question out of plumbing and piping. Now located here, in this topic. Kindly use the reply button to post all replies, add additional information or ask additional questions when replies are posted.
Using this method keeps the topic up to the top of the list of questions automatically.
Web Site Host & Forums Monitor.
Personal Reminder:
Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
Any suggestions
Electric heating???
Heat pump???
Personal Reminder:
Received 1 Upvote
1 Post
Ok we have a heat pump and no heat. Is it the breaker for the outside unit? Are the breaker for the inside unit? At just the tstat can you go to fan on and do you get fan. Have you looked at the out side unit any burnt wires. When you turn the breakers on do they pop off right away?
Like sharp said we do need info so some one here can help you out.
ED
ED
