When my heater runs, my house stinks??
I just built this house 5 years ago, and every year when we use the heater it stinks in here. It's not the smell of something burning like the first time that you turn it on each year...this is a very weird smell, it makes my whole house stink. We called the AC man that installed the unit the first winter we used it, and he told us that it was a smell coming from the pee-trap in the attic, and it was his workers that made the pee trap in the attic. So my husband got up there and changed it and put a real pee trap up there, they had just pieced together pieces of pipe. But this didnt stop the smell coming in. It only smells when the heat is blowing through the vents. So I have another AC guy coming out this week to see if he can figure out what it is. He had said before when I talked to him that some brand new units just smell the rot when they are turned on. Do any of you know what this could be? I have central air and heat.
Thanks...and I hope someone can help me out!!
Kim
Kim
Regardless of how the trap is built it will dry out in the winter and can the pull whatever odor is at the exit of the line.
Best is to fill the trap every few weeks in this case.
Received 1 Upvote
1 Post
Ok you have a heat pump and the ac coil has a drain line on it with a P trap as it should. Now where does this line drain to in the summer? Sound like to me it runs over to a sewer pipe. "If it does thats not to code". The hot air dries out that trap then the unit can get the methane sewer gas in it. Check this out for sure and lets us know what you find. Dont think a 5 year old unit would have a new ROT smell.
ED
ED
dirty sock
There is an odor that starts from the indoor coil that is called dirty sock syndrome.
This is caused by micro organisums that leave waste on the indoor coil and during the defrost cycle the odor seems unbearable. During the defrost cycle the indoor coil gets moist and so does the waste material and then the heat pump goes back into heat mode and heats up the indoor coil and starts to steam off the odor.
I have tried to clean with different chemicals but the one real fix is replacing the return duct and indoor coil.
Received 1 Upvote
1 Post
The drain pipe does go to a sewer vent pipe
the over flow drain pan line goes directly outside of the house.
You can run the main drain line out side also and run it down to the ground with PVC pipe some where.
ED
