heat pump airflow over condenser
Old 12-24-04, 01:38 PM
oopsj
Just replaced cendenser fan. Old fan had only 3 wires, new motor has 4, plus 2 sets of wires to change direction of fan. Worked all main wiring up ok, runs great. Question is , don't remember, which direction the fan should be blowing. Should it be pulling outside thru the condenser or blowing air thru.
Old 12-24-04, 01:54 PM
Ed Imeduc's Avatar
Thumbs up
Should be blowing air up and out.
Make sure you got the same RPM on the motor
ED
Old 12-24-04, 02:25 PM
oopsj
condenser
Thanks
RPM is with 10 rpms. Unit was installed in 1988,Trane, rectangle unit not round. Condenser fan mounts on the inside of unit with the condenser facing outward. Vents out the side of unit. Right now the fan is pulling air thru the condenser and vented out to the sides. Is this right or should the flow be going in the other direction.
Old 12-24-04, 02:37 PM
Ed Imeduc's Avatar
Wink
All Trane 's I know suck in on the sides and blowes out the top.
ED
Old 12-24-04, 03:21 PM
oopsj
Blows out end not top
This unit has a solid top panel, not split unit. Vents on sides, condenser on one end, blower in ducts on other end. I'll asume since all trane units intake air from sides ,blow out, the fan should be blowing thru the condenser instead of drawing air thru it.
Old 12-24-04, 05:47 PM
scottg's Avatar
Location: Wilmington, NC hurricane magnet of the U.S.A.
Air should be drawing air thru the coil not blowing it thru.
Old 12-24-04, 06:45 PM
oopsj
o well
already changed wiring to blow thru instead draw. it's 22 deg, dark otside, and got heat. maybe tommorrow
thanks to all for help
