Coolant Squeal?
Coolant Squeal?
I'm having some problems with my Rheem heat pump. Basically, there is a loud squeal when the heat turns on. I don't think it's a problem with the fan because the fan can be running continuously, and the squeal only occurs when the heating element is engaged. I have inspected the fan and inside heat exchanger, and both are clean and mostly dust free. Also, it does not happen if the heat comes on soon enough after being shut off. There is a slight gurgling noise coming from the plumbing when the heat shuts off. There is no noise when the unit is cooling.
The unit heats and cools well enough, but the squeal is loud enough to wake me up at night. I suspect something with the coolant like air in the system or something like that. Any ideas?
Later.
Later.
If the noise is in the refrigerant lines while the outdoor unit is running in heat pump mode then you could be low on charge meaning you have a leak or it was never charged properly in the 1st place. You will need a pro to check this out.
The gurgling sound , you say is coming from the plumbing. Is this the condensate line "PVC" or is it the copper refrigerant line??
Can you try to isolate the noises to exactly where they are coming from??
