Red light is blinking on thermostat
Received 0 Votes
I have a 10yr old York with a Goodman Handler, there is a red light blinking on the thermostat, 2 slow blinks, what does this mean?
Sorry for the delay Debbie. Can you remove the t-stat cover and see if it tells what the light is for or can you get a model # of the t-stat.
It's possible that it's a dirty filter monitor.
Received 0 Votes
Hey Kool-Aid,
Over the red blinking light it reads EM HEAT, took the t-stat cover off and the only numbers I found are CLASS 2 30V Max LR95329-1 then at the bottom there are more numbers T874R1046 and under that is 2TH11702224A
Also on the t-stat cover it reads YORK but inside the cover itself it reads
Honeywell are they the same company?
Thanks for your help,
Debbie
Debbie
