Heat strips will not turn off
I have a Goodman heat pump with aux. heat strips. My problem is the
heat strips will not turn off. I have replaced the relay or they call it the
(sequencer). I am not exactly sure how this sequencer works, maybe you
can help me. The only other relay is a timer delay relay, with I though was
for the fan. Do you know of any other reason I would be having this problem?
Next start checking the sequncers in the unit its not the tstat. You can pull the 24V wire to them one at a time and see if they drop off. look out when your in there its 220V.
Are kill the power and check it out with a meter.
ED
ED
