Ceiling Heat - Thermostat Question
Old 01-06-05, 09:34 AM
E
My 50's house has ceiling heat. The thermostats are original and some need replacing as they are stiff to rotate the dial. Also they are ugly dark brown and metal.
Are there any programable ones for ceiling heat? If so, anything unusual about the install? If not able to use programable, I guess I need to look for "single pole" ones.
Thanks,
edspilot
Old 01-06-05, 10:19 AM
pgtek's Avatar
hi
check with your big orange box store and ask the clerck what u need
cheers
pg
Old 01-06-05, 03:12 PM
R
If you are talking about low voltage (24 volt) programmable thermostats, then you can find them just about anywhere.
If you are talking about line voltage (120 or 240 volt) programmable thermostats then you may need to look on-line or in a catalog. I found several by using Google back when I was looking.
