Burning Up
Burning Up
Hello, I appreciate your help in advance.
I have a two story house with seperate electric heating systems for each story.
The floor level is fine, the temp is stable and rarely needs to be adjusted, but the upper floor is another story.
The master bedroom is a virtual sauna. Every other room in the upstairs is a bit cold, but not too bad, but the master bedroom is burning hot.
We have all the vents open, except those in the bedroom, which are 1/2 open (they do not close all the way).
What should I do, we cannot go on like this, we end up sleeping on the couch at night.
Thanks
ScottyC
Moderators Note:
This post has been edited.
E-mail address only removed.
Kindly use the forum topics only to exchange information.
Email contact addresses are not allowed in the forum topics...
All information exchanged must be done in the topics.
Including an email address also invites unwanted spam emails....
Removing email addresses spares everyone of that problem....
Doug Aleshire
Super Moderator
Thanks
ScottyC
Moderators Note:
Doug Aleshire
Super Moderator
Last edited by Doug Aleshire; 01-20-05 at 05:11 PM. Reason: No e-mail address allowed within posting
If possible, the best solution is probably to have dampers added to the supply lines going into the master bedroom. The mechanisms on the vents themselves don't usually work well at gating output. Half closed may not do much more than push the air out in a different direction. You may also want to run the fan continuously or on a timed cycle as some thermostats allow.
Doug M.
Doug M.
