heat-pump,oil back-up thermostat????
We have a York heat pump, oil fired boiler back-up that kicks in at 45F outside. We presently have the manual Honeywell heat pump thermostat.
Any suggestions for a good programmable thermostat? Honeywell T8011R?
Thanks
Mr Bill
Thanks
Mr Bill
we tried running the heat pump to 35 and the "cold" heat was uncomfortable.
That is why we added the oil backup in the first place.
We asked our dealer what the other folks in the area do and he said 40-45F.
We go thru about 300 gallons of heating oil in a year so the extra comfort is minimal to our budget.
Received 1 Upvote
1 Post
Hey if the wife is happy with it go for it. You can put more strip heater in the unit to make it warm with elelctric heat if you want . The key here is fuel cost so go to
http://www.warmair.net and compare fuel cost where you are .
ED
ED
The electric strips are still in the unit but unconnected.
They are there as a second emergency setup if the oil furnace ever went down.
It was 0F this morning , noreaster is accoming.
The set-back unit would be useful in that the wife sometimes forgets to turn back the thermostat during work hours.
