changing thermostats
Old 02-27-05, 03:39 PM
24fan1
I am replacing my old thermostat in my mobile home with a Honeywell T8411R
electronic thermostat.The old stat did not have a common wire going to it,but the Honeywell requires one.The Intertherm E2EB-015HA furnace has four wires coming from the transformer.They are grey,green,white and red.Which is my common wire?
Old 02-27-05, 03:49 PM
Ed Imeduc's Avatar
Wink
Check the wire schematic on the door of the unit there.look and see where Common is and what color it is.
R is power red W is white heat G green for fan
Y is for cool compressor
Sounds like you have to pull another wire to the tstat
ED
Old 02-27-05, 06:10 PM
Grady's Avatar
Received 13 Votes on 11 Posts
24fan1
Far easier than pulling another wire in a moblie home, is to get a thermostat which does not need a common.
Old 02-28-05, 04:15 PM
24fan1
thermostat wiring
I already have a couple of extra wires from transformer to tstat.The only wire
not going to tsat is the white one.Isn't the common wire for power to an
electronic tstat?I'm clueless.
Old 02-28-05, 04:42 PM
Grady's Avatar
Common
Yes, the common would be used to power the thermostat. Connect the white wire to the common side of the transformer & C(?) on the thrermostat & you should be good to go. There also might be a C terminal on a terminal strip in the furnace. If so, you should be able to make the connection there instead of directly to the transformer.
