Replace Ruud compressor, or whole pump?
We have a Ruud Achiever 10 heat pump that was probably installed 10 years ago or so. We have had problems in the past with icing in the separate interior unit; a repairman diagnosed a slow freon leak, added more, and it worked again. Now the heat pump appears wholly disabled, and a repair service says that the compressor is grounded to short (causing the circuit breaker to flip). The service says we should replace the whole A/C unit. Is replacing the compressor a reasonable alternative? Any other thoughts?
Thanks so much for any advice.
10 years is getting up there for a Heat Pump. You'd be best to replace the unit with a higher SEER rating (Better rebate), and you know you are covred.
Make sure you get a matching Coil inside as well, and new line set to make sure you are not going to burn out the next compressor.
Matching coil is the A-coil inside your home on your Furnace or maybe you have an Air handler.. it must be changed out on a system change out..
Don't trust a dealer if they says it still will work with the old coil.. It may work. but you are not getting the peek effecney out of it.
Thanks very much. Actually, this service seemed to be suggesting that we swap out the old air handler too (it being of similar vintage), or match up its brand with any new heat pump -- perhaps getting at the same thing. But I'll now be sensitive to that issue.
If you are doing a change out, You will be working with one dealer.. so both system should be the same brand.
Look into the varible speed system for best comfort and quiet.
I am for Trane/American Standard, and also Rheem/Ruud.
Received 1 Upvote
1 Post
Get 3 bid for this job for sure. If you put in all new units lots of companys will give you a 10 year warranty now. trane has a XL16i that has a Seer of 17.00 and a Hspf of 10.55. Rheem has one close to it also.
ED
