Honeywell F100 versus F200 filter?
Old 06-11-05, 02:02 PM
Cool Honeywell F100 versus F200 filter?
What's the difference between the Honeywell F100 media filter system and the F200 system?
I was told that they are pretty much the same... the only difference is that the F200 includes an indicator that tells you when the filter needs replaced.
My situation is that I ordered the F200 but they goofed and brought me the F100 instead. They don't have F200's in stock so it has to be ordered and since they wanted the installation done that day, they convinced me that it's the same container and filter inside... all they need to do is come back later with the part that it's missing when it becomes available.
Am I being totally sheisted? I paid an extra 299 plus tax for this upgrade to an F200. But it seems like I'm probably getting the minimum filter system that they would have given me anyway for no extra money.
I'm not sure what I should do about this. They've already installed the F100.
-Monica
Old 06-11-05, 03:03 PM
hvac4u's Avatar
from what i can tell from honeywells website, the only difference is the replacement filter itself. the 200 is more efficient.
google honeywell 100 and 200, you will not be too happy with your pricing
Old 06-12-05, 12:07 AM
I cannot find a price for the Honeywell F100 air cleaner anywhere on the internet.
What I would really like to know is if I had not ordered any upgrade at all for my air cleaner... which filter system would have been installed as part of my heat pump installation in the first place?
Would it have been the F100 or something even less efficient than that? If it would have been the F100, then I could have saved myself at least 250 bucks and went out and bought the better filter on my own.
Old 06-12-05, 05:41 AM
T
MonicaP
Sorry for your problems. The F200e filter cabinet has a higher MERV(11) which basically means the cleaning efficiency is higher than the F100 which has a MERV rating of 8. I am not certain if you can put a F200 replacement filter in an F100 cabinet and really I don't like that idea. I am providing a link that you can read and make comparisons between the 2 Honeywell Cabinets. I believe there is a toll free number that you can call if you have more questions. If air quality is important to you, then I would make your dealer replace the F100 with the F200. If it is not that important, then make them reduce their price according to the difference between the 2 cabinets. Both cabinets/filters will do a good job, one is just more efficient. Don't accept a compromise that you are uncomfortable with-this is your dealer's business and he should know better.
http://honeywell.electronicaircleaners.com/media.html
Good Luck!
Old 06-12-05, 08:25 AM
TigerDunes -
That's intersesting. You're the first person to say that the cabinet is actually more efficient on the F200. Everyone else is saying it's only the filter itself that is more efficient and has the higher MERV. I've found stuff on the web that says that the F200 filter can be put into the F100 cabinet as well. That part does seem to be true. But I do wonder about the cabinet itself. Would that make a difference?
Do you happen to know whether the F100 is the minimum standard that they would have installed anyway even if I had not requested any upgrade at all??? That's what I want to know!
Monica
Old 06-12-05, 09:30 AM
T
MonicaP,
I don't want to be misleading. The filter cabinet and the filter are made as a system, complementary to each other. The filter for the F200 carries a higher efficiency rating than the F100 filter, Merv 11 over Merv 8. I would suggest that you confirm that an F200 replacement filter is sized where it can be interchanged into an F100 cabinet. I am not certain this is true. As you know, the cabinets are sized for the airflow you require for your system. What size F100 cabinet was installed?
Old 06-13-05, 12:56 AM
How in the heck can I confirm such a thing? The dealer tells me they are interchangeable.
Old 06-13-05, 01:07 AM
This is what they installed:
F100F2028 16" x 20"
uses replacement filters: FC100A1003
Old 06-13-05, 01:10 AM
According to the following link on the Honeywell website, the replacement filters that can be used with the F100F2028 are: FC100A1003, FC200E1003
http://customer.honeywell.com/Honeyw...CFB4218DD64%7D
Old 06-13-05, 11:35 AM
I took it a step further and contacted the Honeywell Product support directly via their website. This is the question that I posed to them:
If a customer purchases the F100F2028 media air cleaner cabinet, but they install the FC200E1003 replacement filter instead of the FC100A1003 replacement filter... will they still reach the highest efficiency ratings and MERV reporting that they would get if they purchased the F200E1003 media air cleaner cabinet? Or... does the F200E1003 cabinet work as a complementary system with the FC200E1003 filter to reach that highest level of efficiency?
Here is their response:
Monica,
Thank you for contacting Honeywell.
The only difference between F100 and F200 media filters are the MERV ratings
of the FC200 media filters. If you used FC200E1003 filter inside F100F2028
cabinet you will still get the highest efficiency of the FC200E1003 filters.
Old 06-13-05, 01:19 PM
T
Monica,
[/QUOTE]
Congrats Monica,
You have answered your question and concern.
Good Luck on your new AC system!
Old 06-13-05, 02:38 PM
yea but I'm still feeling insecure because WHAT IF they were going to give me the F100 anyway as part of the package deal of my heat pump installation?! Then all I would have had to do is buy a $50 filter instead of paying for a $299 upgrade!
The problem is that I don't know if they would have given me the F100 or not. Isn't that the minimum standard filter for a heat pump though?
