Air handler just ate antother transformer
Replaced transformomer a week and half ago
then the blower moter was running constanst fixed that with a tap to the relay. Tonight it tried to start like 3 times then shut down. tranformer is shot agian I did hear it making bumping sounds while running eailer .Is the motor going out and causing it to eat transformers ??? it is not tripping breaker
Yes I am thinking theblower relay is still shot and trying to dop in and out thus over heating transformer and taking it out. When I put in first transformer it ran constant then someone on here told me to smamk it . I did that and it cycled fin for a week .A day or so ago heard it thump while ruunning like the motor was coming back on and off but never realy slowed down( the blower speed) I was haveing a moisture problem can see where the condensation has been rolling over transformer and blower realay.
Man is it gonna be hot in here today anyone know where I can get a transformer in suday grainger is closed.
Btw I used awhite rodger unviseral transformer for the replacement
UPDATE!! Me being a residental electrician assumed that i had 240 going to transformer in the first place you know what happens when assume somthing you make a as out of you and me. THe connections at furnace where not tight and one had poped out NO i did not wire it put they did use copper so no excuse for them some had a lazy helper
A/c is on and cooling it down
