Excessive Dust inside of House
Old 08-09-05, 06:03 PM
I have a new Trane heat pump and air handler installed in a crawl space that has power dry sand . We are getting excessive dust inside the house. What can we do do to decrease or eliminate the dust problem? Thanks.
Jess
Old 08-09-05, 06:23 PM
DirtTrackArt
You may have to change your filters more often. Check your supply and return air ducts at the unit....if the system has gaps at any of the duct connections, the system will draw the dust in. You may want to pick up a roll of chrome tape to get a tighter seal around those areas.
