Thermostat
Old 09-10-05, 04:58 AM
Gizzorge's Avatar
Thermostat
Hey everyone,
I have a thermostat that only controls the central air. Can I use a thermostat with heat/cool settings and just not ever switch it over to the heat setting? Will using this type of thermostat be a code violation?
If so, where can I get a cooling-only thermostat?
Thanks!
Old 09-12-05, 05:57 PM
L
stat
if you have one with heat and ac and you just dont want to put it in to heat and leave it in the cool then just leave it in cool no harm done . but to change it to another stat thats only cooling you most likely would have to change some wires around to make it work.
Old 09-13-05, 09:08 AM
mattison's Avatar
Yes, you can use a heat/cool stat for cooling only. It's done all the time.
