Go Back  DoItYourself.com Community Forums > Heating, Cooling, Air Conditioning, Ventilation and T-Stat Controls > Heat Pumps and Electric Home Heating
Reload this Page >
How do I install a FC200E1037 Media air filter in a Honeywell Electronic air cleaner
Old 09-22-05, 12:04 PM
NAJ
Greetings,
I am trying to install a FC200E1037 Media air filter in a Honeywell Electronic air cleaner case. It is the correct size, and EXACtly the same size as an FC100A1037 filter that my heating co. charged me $100 to put in the slot.
The problem I encounter is that there is a little round metal protrusion from the left side inside the metal casing, that prevents me pushing the air cleaner into the case. This is extremely mystifying and exasperating because an identically sized filter just came out of that slot, and I pulled it out and put it back in several times with no problem!
Before you ask, please let me assure you that this filter is EXACTLY the same size as the one that came out, I compared them side by side. And yes, i have the arrows pointing the right direction.
What the heck is up with this? How do i get the filter past that circluar metal piece that sticks out (about a half inch) ? It appears to be welded on and not removeable. Obviously it was there when the other filter was, so I am completely mystified..
PLEASE HELP!!!
thank you,
N. Jacobs
Old 09-25-05, 09:51 AM
hvac4u's Avatar
this may help
Fits Honeywell 20" x 25" x 4-" media air cleaners, including models F25A1068, F25F1067, F35F1024, F100F1038, F150E1034, F200E1037.
Can be used to replace collection cells in Honeywell electronic models F50A1066, F50E1141, F50E1166, F50E6066, F50E8005, F50E8047, F50F1081, F55A1384, F55A1400, F55A1434, F55F1003, F55F1037.
how does the other filter avoid hitting the protrusion?
Old 09-25-05, 11:22 AM
NAJ
That's the million dollar question. I'm really not as stupid as I must sound. This is just really mystifying...
Old 09-25-05, 01:35 PM
hvac4u's Avatar
can you remove the door to the unit to access the track while sliding in the filter?
Old 09-25-05, 04:01 PM
L
filter
the old filter was it pushed in on the bottom on one side to pass circluar metal piece. if so when they put the frame in thay might of made it to small with out telling you and crushed the filter to make it fit . if so id be calling them back out to fix it right.
