Klimaire mini split problem
I have a Klimaire mini-split heat pump. The electrical connections to the outside unit were pulled out. I reconnected the wires correctly after several tries and the unit runs, but the controls to the outside unit do not seem to be working correctly (no heat and even when turned off, the outside unit will run on and off). I can not find anyone who services this type of unit in the SF Bay area. Any ideas on how to fix, what might be wrong?
Thanks!
Rob
Thanks!
Rob
