Help identifying sequencer replacement part
I am having difficulty figuring out which replacement sequencer I need to order.
The sequencer I am trying to replace is made by Klixon.
Line 1: 24V
Line 2: 60000A0 11
Line 3: H30-70 C1-40
Line 4: F0V 175
Looks similar to this, except it only has a single connector on each side of the bottom section.
Thanks
Line 1: 24V
Line 2: 60000A0 11
Line 4: F0V 175
Thanks
I haven't been able to locate anything that identifies the inside unit. The unit appears to be the original unit, which would make it 20+ years old.
Sometimes when the heat turns on the air is not being heated. I had a technician look at it, however the problem was not occuring when he was diagnosing the issue. He suggested that either the sequencer or the snap limit was failing intermittently.
Both parts seem fairly simple to replace and much cheaper to do myself, just have to figure out what replacement part is the correct one.
