Honeywell T8011R
I purchased a Honeywell digital programmable theromostat T8011R off Ebay, good price, but can not find a cross reference chart to wire it in.
I have a American standard heat pump that is wired to a manual thermostat as follows:
Red wire to R
Brown wire to T
Orange wire to O
Green wire to G
Yellow wire to Y
Black wire to X2
Blue wire to B
White wire to W
The Honeywell thermostat has the following terminals:
G
C
R
W1 (jumpered to Y)
Y
L
W2
E
B
O
Can anyone tell me the correct way to wire this up?
Red wire to R
Brown wire to T
Orange wire to O
Green wire to G
Yellow wire to Y
Black wire to X2
Blue wire to B
White wire to W
G
C
R
W1 (jumpered to Y)
Y
L
W2
E
B
O
Brown wire to T
G green
C blue
R red
W1 (jumpered to Y) white
Y yellow
L
W2 black
E
B
O orange
Brown wire to T
G green
C blue
R red
Y yellow
L
W2 black
E
B
O orange
I am not sure where the black t goes to.. go back to the air handler, and take a look to see if you can make something out of it. and double check the other wires.. Please do this before you undo your old t-stat.. and if you find it, then make NOTES, and turn OFF power.
Was your old stat mercury bulb? Where did you hook the brown wire to? A digital stat doesn't have a T terminal. I'm not sure but you don't nned the brown wire. I don't remember the wierd stuff that was happening when I found out.
I climbed up into the attic and found the manual still on the air handler upstairs. I guess I forgot to mention I have an air handler upstairs with attached outdoor heat pump.
The manual was still attached to the unit. In the manual was a field wiring diagram for the air handler with a heat pump. The wiring diagram indicated the following:
Room Thermostat Control Box
R to R
T TO Y
O TO O
G TO G
T TO T
W TO W1
X2 TO W2
B TO B
Also, the heat pump is a American Standard Model BAYHTRN110A. Does this help?
R to R
T TO Y
O TO O
G TO G
T TO T
W TO W1
X2 TO W2
B TO B
Ok, This is what I got figured out.
T-stat-----wire color-----Air handler
R-----red----R
W2-----white----W
O------orange----O
W1 and Y-----yellow--- Y
E-----black-----W2
G----Green-----G
C------blue----B
T/Brown is not used. Tape it off.
R-----red----R
W2-----white----W
O------orange----O
E-----black-----W2
G----Green-----G
C------blue----B
I just finished wiring up the new thermostat, programmed it, and then cycled it through a heat cycle, and then a cool cycle. It looks like everything is working !!!! Jay11J THANK YOU FOR YOUR HELP !!!!!!!
