New Electric Furnace Suggestions
Old 07-25-06, 11:29 PM
H
I purchased a piece of property with a 28 x 40 building with no heating. It needs a new roof and is drywalled completely with 2 doors, 8 windows and a garage door. Does anyone have any suggestions as to any electric furnace I should be looking at?
I do not need air conditioning, but one that would be sufficiently heat this building well. 220 and 440 are available.
Thank you!
Old 07-26-06, 12:55 PM
F
It is utterly impossible to make even a guess as to what size (I assume that is what you want) electric furnace would be required with the sparse details that you have provided.
Old 07-26-06, 04:59 PM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
WELL first what will you do in it??? Horse's????
If open inside Id go with 2 electric unit heaters. Like the gas ones. Hang from the ceiling one blow down one side the other blow back up the other side of the builing. AS far as size you have to run a heat loss on it. Id get some insulation in the ceiling after the new roof.
ED
Old 07-26-06, 08:30 PM
B
1120 sq. ft of floor space, hmmmm , thats all we got, like the other guys that posted (ed and furd) please remember, we ain't trying to be b- holes
or the like but the more info we have the better we are to help,
another thing to keep in mind is that we are not at your house,farm or property we are here to help, but the more info you can give us the better the info we can give you. thanks a lot for visiting DIY forums
barry
Old 07-26-06, 09:26 PM
H
Sparse??
Not all all, name of electric type of furnace suggestions, I can calculate the size.
Building is insulated and drywalled even the ceiling
28 x 40 with concrete floor 12' high walls.
Old 07-27-06, 04:30 AM
mattison's Avatar
If it has to be electric I've had great luck with Dayton heaters and they come in sizes that would probably fit your application. If you have an account at Grainger that would be the place to get them.
Old 07-28-06, 07:42 PM
H
Just what I needed, a suggestion as to name brand etc.
So I will start looking.
Thank you.
