UPM Programmable Line Thermostat
I purchased an UPM Programmable Thermostat - HTM311A - for use with an electric King 240V Wall Heater - DEC2422. When I install it (inline series in a 240V - 30amp circuit) the thermostat never turns the heater on. It is supposed to have a fireplace ICON which never comes on. If I manually connect the two input wires to the thermostat, the heater runs properly.
The face has 3 readouts - time, room temp and set temp. When I advance the set temp and reach 2º over room temp, the horizontal lines between the readouts flash but the fireplace ICON never appears and the heater never turns on.
Has anyone had experience with this thermostat? What do the flashing horizontal lines mean? What could be my problem? Any suggestions?
jimhorn1
jimhorn1
Similar experience
jimhorn1
jimhorn1
I'm going to take a crack at the help line tomorrow.
Mystery Solved
I talked to the help line and was told that flashing lines mean that the unit is toast: blown fuse or something. It could have happened in shipping or during installation. I got the impression that they are pretty fragile. I was told to take it back.
