acting up hp (Heat Pump)
My compressor sometime runs outside but no fan inside? Sometimes you put fan to on and it will run and sometimes not? Last nite removed red and green at the thermostat touched and no fan ? help
Received 1 Upvote
1 Post
Dont know what you have there. But can be the board, the blower relay, the heat speed, on the blower motor. If it runs in cool you can turn the tstat to fan on and let it run . The heat should come on and off for you . till you find out what is wrong and get it fixed
