Heating new room in the attic in New England.
I already posted this in Attics, but didn't get any responses. Maybe someone here can help.
We have given up on our original plan for heat. I am now considering electric heat or bringing the steam up to the attic. I need some cost/benefit advice on the choice. I am also open to any other suggestions.
Electric:
I don't like electric heat, at all.
It will be more expensive to run, but the room will be used for a relatively few hours a day, and the room will not suck heat out of the rest of the house when unheated.
I think it will be cheaper to install.
I think it will heat the room more evenly and more quickly, but I have never had electric heat, so I am not certain about that.
Steam:
I love steam heat. I love the hisses and clanks.
I know it will be expensive to install.
I am afraid it will take much longer to heat the room.
I think that if I have a single radiator, the room will heat unevenly; I don't want a cast radiator in the attic. [Are there baseboard steam heating units?]
I don't know how I could turn it on from the second floor [to let the room warm up before I go up there].
Any advice, insights, or alternatives will be greatly appreciated.
More information:
The house currently has natural gas fueled heat, with cast radiators in the rest of the house.
This will be a pretty big room, about 25' x 16', with a pretty low ceiling, under 7', 3' knee walls. The floors are insulated, have thin plywood over the original rough plank flooring; the knee walls and sloping walls and narrow ceiling will be insulated.
The room will be used primarily in the afternoon and evening [after the sun has been on the roof all day]. The intended use is as an office, but may be used as a kids' den by the next owners [not that we are planning on selling just yet]
Electric:
Steam:
More information:
A gas fire place WAS the original plan.
Unfortunately, the fire place was over $1000, not including installation, and would require a hole in the roof. The hole in the roof was the deal-breaker
I was told that we should under no circumstances even consider any kind of ventless gas heat.
Sigh. I don't want electric, but I just don't know if bringing the steam up would work.
Carbon monoxide?
I have spoken primarily to gas stove salesmen who basically say that all the stuff that is supposed to go out a vent goes into the room, and that is bad.
I've just assumed it was carbon monoxide ...
Received 1 Upvote
1 Post
In no way do you want to use a ventless gas heater there. In fact in many states they are outlawed. You have it right about the carbon monoxide . When the talk about safety they have a automatic safety shutoff sensors to shut it off at low oxygen.By then the carbon monoxide has got you.
You now have gas for the boiler Id say a small gas furnace or a small vent gas heater. Cant you tie into the flue from treh boiler ??????. The small gas heater and flue will cost a lot less then that $1000 And you can turn it on and off when you want
I have never heard this! I thought that this was the way to go! With the Lack of a lot of hrs the room would be in use I can't see CO being a problem. Is their windows up their?
Tieing into the current flue:
Definitely illegal here; each unit [water heater, furnace, stove vent] must have its OWN outlet.
And every home, even owner-occupied single family, MUST have carbon monoxide detectors; rental property must have hardwired smoke detectors with battery back-up, but I don't know if OOSF do.
I would love a gas fire up there, but a total cost of $4K, just doesn't seem worth it.
