RUUD Heatpump not warming up home...
I have a RUUD Heatpump (I think the model is UHQA 1200 BCS - that's what i read on the front of the unit) inside the home and a unit on the roof that is attached to the Heatpump (I think it's the A/C unit but not sure), but not sure how they are attached. I don't know much about this insde and outside units, but I do know that when I turn on the heatpump at the thermostat to the Heat position the home is not warming up and the air that is coming out the vents is not warming up either.
I replaced the filter and went up to the roof to reset the outside unit by pressing the button that was labeled press to reset, but the no warm air still.
I'm not sure what else I need to check but would appreciate anyone giving me guidance on what next steps to take. Thanks in advance!
Both units are running...
Sorry for the late reply. I was expecting an email when a reply was posted but never got one. Thought I check to see if there were some replies and apparently there were.
Yes, both the outside and inside units are running.
The emergency heat is does not appear to work either.
BTW, I remember one of the pipes (don't know what else to call it) that protrudes from the inside unit into the wall used to get warm when it worked, but now it doesn't obviously. Please let me know what more information I can provide.
Thank you in advance!
