Coleman Electric with only slightly warm output
Old 01-04-07, 07:10 AM
O
I just purchased a Mobile home with a Coleman Electric furnace Model 3400A816. The furnace cycles, but only puts out luke warm air. Any suggestions as to where to start troubleshooting? I have a digital multimeter and am reasonably capable with it. I am no HVAC man but can follow instructions. Thank you
Vic
Old 01-04-07, 10:01 AM
Ed Imeduc's Avatar
Wink
Is this a heatpump or just a electric furnace??? Is outdoor unit running ??? If just the inside do all the elements come on that you have??? Info info help us help you . Stay in this same post.
Old 01-04-07, 03:26 PM
O
This is not a heat pump, it does have central air a coil but is not a heat pump. I do not know if all the elements are coming on or not, please help me by telling me how to determine that. Thanks!
Old 01-04-07, 04:01 PM
Ed Imeduc's Avatar
Wink
Know what you are doing!!!!!! Amp them out when the furnace is on. Check and see if each has 220V. If so with power off Ohm out each element and see if they are good.
Is this new or old . Is the filter clean. The AC coil clean ?????
