GE Zoneline PTAC Heat Pump
After not using my Zoneline heat pump for a few years, I turned it on but it blew only cold air. I turned it off and then one night it came on by itself, blowing warm air. After a few days I noticed that it was not cycling off/on and I couldn't turn it off so I unplugged it. A few weeks later, I plugged it back in and again, nothing but cold air. Any suggestions? Also, should the unit be set for "normal heat" or "emergency heat"? I believe it has been set on emergency heat in the past.
Thanks.
Thanks.
Received 1 Upvote
1 Post
Id say can be anything after that time. The switches and the tstat in it . There points can be bad from just setting around . Bugs can get into things like this also. Id go into it and see if you can find anything.
