Heat pump makes lights go dim
Old 04-08-07, 07:58 PM
When my heat pump turns on, some of my lights in the house go dim. The house is 4 years old, the problem has existed all the time. The house has 200A service. The problem is more evident with any light that is on a dimmer (and we have several).
Any ideas about what causes this and how it can be fixed?
Thanks!
Old 04-09-07, 06:01 AM
mattison's Avatar
You could see about getting a hard start kit installed for the compressor. The dimming of lights on start up is pretty common and normally don't cause a problem.
Old 04-09-07, 12:57 PM
Ed Imeduc's Avatar
Wink
If you know how!!!!!! Might check all screws on wires in panel and in the unit. See if tight. Could amp it out and see like Matt said. Put a start kit on it
