Heat pump trips breaker
Old 04-29-07, 06:09 PM
Hello....I have a Tempstar 5000 heatpump that constantly trips the breaker. Unit is 15 years old. I reset the breaker and can hear a buzz from the compressor and fan is not on then immediately trips the breaker. I'm guessing compressor may be locked? Just trying to get an idea of the possible problem. thank you
Old 04-30-07, 03:21 PM
Ed Imeduc's Avatar
Wink
Check out the capacitor for the compressor. Check all wires. Id say call a tech to check it
Old 05-01-07, 08:19 AM
Our Carrier (20 years old) does the same; outside compressor trips 30Amp breaker. I notice much heat from the compressor when this happens, so the compressor (I assume) is overheating for some reason. We're looking to replace the entire system, although that may not be the best approach for many.
Old 05-01-07, 10:33 AM
Ed Imeduc's Avatar
Wink
rambo2_981
Can over heat cause its low on freon.
