where do i install float valve shot off.
I have a float valve "t" shut of switch where do I install the emergency shut off leads. Its to shut the system when the primary drain line fills up with algea or gook. there are two mystery wires in the condensor out side. I don't know where to begin to look.
sincerely
Nick
sincerely
Nick
Received 1 Upvote
1 Post
You can work it in on a lot of lines. But Id put it in line in the Y wire going out to the compressor. That way the inside fan can still run. But this will turn off the outside unit if you have water in the pan.
