have ifey interior fan
my outside unit comes on and the interior fan does most of the time then out of the blue it don't work? turn it all off and reset thermostat and works.repair man comes out and said thermostat is bad! so he changes it , works good for three days and starts doing it agin? whats up ?
when the outside unit comes on and the inside don't you can flip switch to fan on and it will not come on but after about 25 mins the fan will come on . then let fan run in the on postion for 20 mins flip to auto and it all work fine.
most likely the fan motor is overheating due to worn bearings or a bad motor capacitor ther other problem could be worn contact points on the motor relay. when the motor goes off is it hot or cold to the touch?
cold = power not getting to the motor [relay problem]
hot = motor is shutting off on it's internal protector [motor or capacitor problem]
