Heat pump keeps running
My system as started to act strange. I don't know how long it has been doing this; however, I just noticed it today.
The blower is not running and the thermostat is showing the set temperature. For some reason, the outside heat pump is still running. The line that is not insulated (I believe this is the return line) is cold and has frost on it.
I disconnected the thermostat and the pump kept running. At this point, it appears that the system switched over to heat. Within a couple of minutes, the return line thawed and got hot.
I cut power to the inside unit and the pump kept running. I then restored power to the inside unit and cut power to the pump. Obviously, this shut down the pump. When I reapplied power, the pump came back on. So, I cut power to both units and then reapplied to the pump and it came back on again. I removed power from both for about 15 minutes and then turned both back on. The pump stayed off this time.
Is there a relay in the pump assembly that could be causing this problem?
Indoor unit
Carrier
Product # - FB4ANF030000AFAA
Model # - FB4ANF030
Outdoor unit
Bryant
Product # - 663CJX030000ABAA
Model # - 663CJX030
Indoor unit
Carrier
Model # - FB4ANF030
Outdoor unit
Bryant
Model # - 663CJX030
Well, it did it 2 more times after posting. Both times I popped the breaker for the outside unit and let it sit with no power for at least 10 minutes both times. It has been operating normal since.
Any ideas as to what could have been causing this?
