Concerns about heat pump thermostat installation
Hi there,
I’m having some distress installing my new Honeywell thermostat. Not all letters on my old thermostat are matching the new one! Look at the pictures below; do you think I need a professional installer?
Terminal assignments description:
Aux. - Second Stage Heating
B - Change Over in Heating for Heat Pump Applications or Heating Damper in conventional forced air systems
C - Common
E - Emergency Heat
G - Fan Relay
L - System Monitor or Defrost
O or O/B - Change Over in Cooling for Heat Pump Applications
OT - Outdoor Sensor
*R-24 - Volt Power Wire
*RC-24 - Volt Power Wire from Cooling Transformer in Dual Transformer Applications
W(or W1) - Heat Relay
W2 - Second Stage Heat in Multi-Stage Heat Pump or Multi-Stage Forced Air Systems
W3 - Third Stage Heat in Multi-Stage Applications
X - Common
Y(or Y1) - Cooling Contactor
Y2 - Second Stage Cooling in Multi-Stage Applications
L1 and L2 - Line voltage wires coming from the circuit breaker
T1 and T2 - Line voltage wires coming from the electric baseboard heater
* In single transformer systems always use jumper between R-RC terminals.
C - Common
E - Emergency Heat
G - Fan Relay
OT - Outdoor Sensor
X - Common
Back up source: Oil
Heat pump out side: Lennox HP16
<object width="450" height="500"><param name="allowScriptAccess" value="SameDomain" /><param name="movie" value="http://static.scribd.com/FlashPaperS3_6.swf?guid=bdd83rl4i4sz4&document_id=397453" /><embed width="450" height="500" src="http://static.scribd.com/FlashPaperS3_6.swf?guid=bdd83rl4i4sz4&document_id=397453" type="application/x-shockwave-flash"></embed> </object>
In door unit: CETLUS upflow warm air furnace, model MBOV115DABR-B
<object width="700" height="500"><param name="allowScriptAccess" value="SameDomain" /><param name="movie" value="http://static.scribd.com/FlashPaperS3_6.swf?guid=ijmtka0vnaaoq&document_id=397374" /><embed width="700" height="500" src="http://static.scribd.com/FlashPaperS3_6.swf?guid=ijmtka0vnaaoq&document_id=397374" type="application/x-shockwave-flash"></embed> </object>
Thermostat: Honeywell 7500D
<object width="450" height="500"><param name="allowScriptAccess" value="SameDomain" /><param name="movie" value="http://static.scribd.com/FlashPaperS3_6.swf?guid=1b8270hav46il&document_id=397464" /><embed width="450" height="500" src="http://static.scribd.com/FlashPaperS3_6.swf?guid=1b8270hav46il&document_id=397464" type="application/x-shockwave-flash"></embed> </object>
Thanks for the info.. I will post back later on, a friend is stopping by in a few min. I need to cut some wood for him quick on my table saw.
One more question, you got a sensor for outside?
Yikes.... I looked at the books closer, your t-stat will not work with this set up.
On page 18, you want Heat pump with Aux back up. It's not listed.. Says heat pump without Aux back up.
I'd suggest you to return that and get a good Honeywell VisionPro TH8320 t-stat, along with an outdoor sensor.
Ok, I think I got it to work.
A couple of questions for you.
-Current/old t-stat, do you know if the oil kicks in when the outdoor unit goes into defrost?
-Is there another relay near by the outdoor sensor or on the furnace? (See page 9 of your heat pump book, the emergency heat relay)
The way I am going to wire it if you got the emergency heat relay, and when the heat pump goes into defrost, it will be blowing cool air out of the vents till it cycles back into heat mode. Really shouldn't be using the furnace when it goes into defros cuz it put out a lot of heat, and may be hard on the compressor outside.
Any update for me?
I kinda got something together, but I need to know more info on a relay that the burner maybe on.
Otherwise, to save the mess, "clean house" and put in the Honeywell TH8320 w/ outdoor sensor.
Hi Jay,
Sorry, just got back home…. Exhausted…long day.
You know what, outdoor unit is not kicking anymore…I don’t know what happen!! Completely dead! I don’t really need this!
I looked around; there are a lot of stuffs that I don’t know what are there for. Will take some picture and post them during the week end.
Thanks Jay
Thanks Jay
I've played around of what we've got so far. I am afraid it's not going to work at all.. At first I thought I had it... But no.
if we went what I had planned, the burner will come on any time if the outdoor temp falls below set point, and never shut off till it warmed back up outside. I don't think you want to over heat the house!
BUT, unless that outdoor sensor has 3 port, (Open, Close, and Hot) then I might be able to get it to work. But I"ll wait till you post back.
I also have a Lennox
Try to e-mail them and give your HWell stat #, your Lenox stat # and the letters off your Lennox stat. I went through their web site and they responded within 24 hours. My Lennox had 1 or 2 terminals that did not match up to anything in the HWell install manual. One was for what appeared to be an outdoor temp sensor and the other for "service system". They told me they didn't have a "consumer installable" stat for my Lennox. Here is the e-mail address from their response.
ECCCustomerCare@Honeywell.com
