Bryant Electric Heater Problem
Hi to all,
My Bryant heater's circuit breaker has just started tripping.
It start doing this about 12 hours ago. When I reset the circuit breaker the heater runs about 10 minutes and the cuts out. Is there a fix I can do or is time to call in a professional? TIA
Sounds like you may have an element shorting on you.
I don't know that mode, but not sure if the banks of element is able to pull out and take a closer look at it?
Does it stay on when you turn off heat, and just run fan or A/C?
