Honeywell RTH3100C heatpump wiring help needed
I replaced my mechanical thermostat with a Honeywell RTH3100C digital. The heatpunp is an old Rheen. The wires coming from the heatpump are R,Y,G,W and W1. They are hooked to R,Y,G and W & W1 are hooked to Aux. The fan and compressor run but the only heat is coming from the heat strips when I set the thermostat 5 degrees about the roon temp. There is no help on the Honeywell site and nothing that I can find on this site seems to be what I need. I tried hooking the W1 to B and that didn't seem to help. Any guildance will be greatly appreciated
Jerry
Jerry
When you set the t-stat that high above room temp, the Aux will turn on.
Set it only for a degree above set point, and Aux may come on at first. but after a few min, should shut back down.
Did you do menu set up of heat pump w/ aux heat?
At the air handler, is there W and W1 as well?
Jay
On this old Rheem the entire unit is outside and yes the thermostat wire connect to R,Y,G,W and W1. I understand what you said about the heat strips kicking in when I set the thermostat to high. From the amount of activity on this site with your name on it, I expect you know what the thermostat looks like.
Jerry
Jerry
If it's a heat pump one of the wires need to go to the O/OB on the t-stat..
Since I don't know Rheem's packaged heat pump, I am going to need a model # and look it up, and see what is what for the W and W1.
Jay
The unit is a "Rheem Corsaire"
Mfg # P55660-10C
Serial # R464200315
On Underwriters tag #SGP30-1
I sure am happy you replied because you seem to be the Hotshot on this site!!
Jerry
Mfg # P55660-10C
Serial # R464200315
Jerry
I am afraid that's not a model #.. Rheem's Model numbers should start off with smothing like RKxx-x##
Are you able to take a photo of the wire schematic that may be hind the blower door for me?
I am not able to find anything on that model, and I am not sure what W and W1 is for.
Thanks
Thanks to Jay and Ed for their help. I had my service man out today and he couldn;t get the thermostat to work either. The newer thermostats do not have the proper connections to work with my old heatpump. Two relays we not working in this old heatpump and I decided its time to replace it with a new more efficeint model.
Thank You Jerry
Thank You Jerry
Jay
I am getting a new Rheem and a new thermostat. The old and new heatpump are "over/under outdoor units. On a different question, I have had 3 houses with basements and none had a cold air return in the basement. I guess this is normal since the 3 houses were in different states. But is seems there should be a return to keep the air in the basement moving and to collect the cooler air that would collect there especially in the air conditioning season.
Jerry
Jerry
