fan speed/ new install
Just had a trane 5 ton total replacement. The fan speed is set to high by factory default. The problem is that the temp of the house drops quickly but the system doesn't stay on long enough to effeciently lower the humidity (Florida). A lower fan speed will solve the problem. My friend, who owns the AC company that installed it WILL come back to lower the speed BUT he is on vacation for 3 weeks. No big deal, but I was wondering what switch/jumper I can set to do the job. I have over 35 years in the electronic industry so I'm not shy about doing this. I just can't find a service guide or schematic.
Thanks
Thanks
Received 1 Upvote
1 Post
[QUOTE][The problem is that the temp of the house drops quickly but the system doesn't stay on long enough to effeciently lower the humidity (Florida). A lower fan speed will solve the problem. My friend, who owns the AC company that installed it WILL come back to lower the speed/QUOTE]
Im like Jay---What A friend to put in to big a unit ?????
Down there in FL. Id put a humidistat on the unit . Check the wire lay out on the blower door . It goes from R to BK in the unit. This will cut the blower speed down for you. IF THIS IS A V/S blower.
fan speed
Thanks everone. I opened the unit and found the schematic.......DUH!
It's a 3 speed fan. Lowered it to medium speed and runs perfect. 5 ton is the correct size. Original was 5 ton and home is 2600sq ft
Thanks again, I should have looked around before posting
