heat questions and PROBLEMS
question......with an electric heat pump,(central heat and air) should the outside fan (condensor fan?) be running? (to get heat)
would a low refrigerant charge keep it from running?(heating)
the blower fan runs, but I have no heat. Can something be jumped to get the outdoor fan running without hurting the unit until I can get a pro out? thanks for anything!
problem solved and a lot learned. got in touch with an old friend in the trade, low refrigerant, charged up, GOT HEAT!!
outdoor fan came on , all's well......
possible leak, but I'll deal with that a little later
